ISIS could not be started on the specified VR.
This indicates that the switch is running low on memory resources. Reducing the size or complexity of the switch configuration may alleviate this issue. The ISIS process will need to be restarted. If the problem persists capture "show tech" output and contact customer support.
Warning
ISIS failed to initialize on VR %VRName% VRID %VRID% error code %errCode%
| Name | Type |
| VRID | uInt |
| VRName | String |
| errCode | uInt |
